over heat
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: over heat
- Has thanked: 603 times
Re: over heat
One question....has your boat been this way with both engines since you have owned it ?????
Re: over heat
I hope I'm wrong but I'm not confident that the gasket on the strainer is the issue. I've seen way worse than that with no ill effects on runability but did result in water leaks at the strainer.
You said they ran fine before you replaced the impellers but everything looked fine at the pump, question; was this the first time you replaced the impellers in this application? What part number did you get? And did you by chance keep the old impellers?
Looking forward to your findings on these and the questions I asked earlier. Weekend homework
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Re: over heat
Even when this does not solve the problem as a whole, it will be part of the solution.
In the end nothing beats a good sea trial. Even without any problems
Re: over heat
That lid is a stupid design when it comes to compressing a gasket evenly all around.
Agreed, even Groco realized it was not the best as the design has been changed at least since 2007 when Midnight Sun was produced as mine is similar to the one below. The top is spin-on by hand and a simple O-ring crushed flat when tightened does the trick and is easily replaced. Here is what they look like now. https://www.groco.net/products/raw-wate ... arg-series
- Phrancus
- Contact:
Re: over heat
I'd design a drop in (tube in tube) on a gasket and then a manual clamp to press it in place. And a gasket that allows for serious McGyver solutions when things go broke out at sea.
- pepmyster
8.1 Volvo Penta
Re: over heat
Hans,,,,Here is what they look like now. https://www.groco.net/products/raw-wate ... arg-series. I like the drain plug on the bottom.
- pepmyster
8.1 Volvo Penta
Re: over heat
