Port engine stalls while running after a while
- Ctmangrum
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
Re: Port engine stalls while running after a while
- Ctmangrum
- Ctmangrum
Fine once I changed the coil. Did a quick tune up while I was there also. We will see.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
up to the next...
Small curious question as a non-native speaker: what do you mean with 'a tune-up while you were there? '
- KandJ72
- Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process - Location: Central NY
- Has thanked: 20 times
- Been thanked: 3 times
This is if your running OEM PCM replacement coils, aftermarkets will usually run a little higher except for high output like Accel, Bosch etc. I installed the Hot-Spark ignition conversion kit in my '76 Carver 3396 with twin 351W, LOVE them. Easy start EVERY time! Much less expensive than Pertronix. Never mess with points again.
- SGI390
- Vessel Info: 1993 Carver 390
Crusader 454 Engines - Location: St. George Is., Florida
1986 26' Carver Santa Rosa
1995 26' World Cat
31' Contender Open
1993 Carver 390
