Shore power (No power)
- claytonandresen
- Vessel Info: 2004 Carver 42 Mariner
- Has thanked: 1 time
Yesterday when I went to my slip I noticed everything was off (connected to shore power)
Did the usual:
Checked breakers (nothing was tripped)
Checked plug (no black marks- looked fine)
Reset everything
Plug into a different shore power unit (still no power)
Generator runs everything fine- but when I switch to shore power it has 0 amps and the shore power green light doesn’t illuminate.
Any suggestions would be appreciated.
- Has thanked: 602 times
Re: Shore power (No power)
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
If all the power is working in the boat when the generator is running, then it sounds like it is a shore power issue as stated by Bud37.
Edit: I just had another thought. This happened to me when I had my 356. I was using my generator and all was well. I then turned the generator off and plugged into shore power, nothing. After looking into it I discovered that there was a transfer switch behind the panel. It appears to have been stuck. I gave the panel a smack with my fist and it was enough to jolt it open and everything was fine. I had to do this on other occasions as well.
Hope this helps you.
Greg
Tireless wrote:Source of the post
There are a few threads on here where folks had problems with the relays in that transfer box and some links to sources for replacement parts. Just by cycling the generator once or twice you might be able to get the shore power to work again, but that indicates a problem with those relays, so you just might be delaying replacing them.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- claytonandresen
Marina has power, but their was a lighting strike at a nearby dock late last night the effected some boats. I’m having a electrician try a solve the problem today.
I’ll let you know the fix.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Your boat perhaps wants a certain voltage between the pins to operate (more amperage by using the pins smartly). Even though a quick check on shore with something that needs only a simple connection makes it seem that all is ok.
Nevertheless: get that relay checked and get a replacement in the toolbox would be my suggestion.
claytonandresen wrote:Source of the post Marina has power, but their was a lighting strike at a nearby dock late last night the effected some boats. I’m having a electrician try a solve the problem today.
AHA....thanks for posting....hopefully it turns out to be their problem.....good luck...
- claytonandresen
Thank you everyone for your input.
