2006 mariner 36
- Maikgruft
- Vessel Info: Marina36 2006 volvo penta engines
2006 mariner 36
The boat has the 5.7 volvo penta engines .
The survey found no issues with the boat .
The engines both have 300 hours on them .
As it was stored in a heated place 2 hours away from location , I brought over the water to my home .
My problem is that both engines only make 3200 rpm and then stull out .
When I reading correctly the engines should make 5500 rpm .
As I ask a mechanic ,he said it could be the wrong probs .
But it still shut off on me , even in neutral at 3200 .
If it would be the gas pumps, then either off the engines would shut off at diffrent idel.
Any one out here no what my problem is ,or if it is from carver restricted in the beginning.
Thanks for any input
- Has thanked: 603 times
Re: 2006 mariner 36
Your engines are electronic/computer controlled and with the boat being new to you, maybe not a bad course of action.....good luck with your new boat.
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: 2006 mariner 36
Re: 2006 mariner 36
Re: 2006 mariner 36
When were the fuel filters replaced... and do you know if ALL the fuel filters were replaced? Some boats/engines have multiple sets of filters in line, so any one being clogged up will limit engine performance.
Re: 2006 mariner 36
When running in gear, those engines should make at least 4500 rpm. I wouldn't push them to 5500 for more than a minute, just to see if they can get there.
Re: 2006 mariner 36
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 2006 mariner 36
- JohnS
- Vessel Info: 2003 350 Mariner
- Has thanked: 39 times
- Been thanked: 16 times
Re: 2006 mariner 36
- JohnS
Re: 2006 mariner 36
New rotors, caps and plug wires same issue so after a lot of research i replaced the fuel injectors with a set of rebuilt ones, 4200 rpm and she runs like new. I'm sending the old injectors out to have them cleaned and will be changing out the port injectors.
https://highperformanceinjectors.com/pa ... g-services
