What is it?
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
What is it?
- Has thanked: 602 times
Re: What is it?
Re: What is it?
That looks like one with a bladder (all the bolts around the 'top' where the hose connects to). That means it should also have a air valve to check and adjust the air pressure on the other side of the bladder. You adjust the pressure based on how your potable pump pressure is set.
Also, the way that's mounted you need to be concerned about draining it in the "offseason". Mine was mounted with the hose at the base and above the water lines so that it would always drain down into the water line so that water could be evacuated from the system. The way yours is mounted there's no way to get the water out of the tank, so it could freeze in the offseason (and it'll also be some stanky water after sitting MONTHS AND MONTHS in there!)
It looks like that's right inside the cabinet door and to the right on the port side of the aft berth. Am I correct? I'm wondering where that hose goes to when it goes "up"? I it's like mine, the potable pump is under a hatch in the bottom of that cabinet.
Re: What is it?
That being said if it has been there for a decade plus, the bladder is probably dead and pretty much useless at this point. Just like tires in your car, they do need air addition/adjustment once in a while, not just install and forget.
Re: What is it?
- Grafunkus
- Captain
Re: What is it?
km1125 - that is exactly where it is located. However it is not mounted to anything at all. This is it pulled out of the cabinet.
I don't understand where the air valve is located. Are you guys saying it is in the container?
I am sure the bladder is "dead". It almost looked like there was "dried" stuff in the lines. If the boat had been on city pressure, then this wouldn't have been required - correct?
Re: What is it?
Grafunkus wrote:Source of the post I don't understand where the air valve is located. Are you guys saying it is in the container?
Likely under that black cap on the bottom of the tank.
Re: What is it?
Correct, simply will aid in removal of pulsing pressure when using the potable water pump. Serves no purpose when connected to city water.
Re: What is it?
Re: What is it?
It should be fastened so it can't bounce around in your boat, but it can be mounted in any position.
