What is it?
Re: What is it?
Re: What is it?
- Has thanked: 603 times
Re: What is it?
.... would be to remove that from the boat, then and if it comes that you need one, get one of the small marine ones. That will remove all doubt and wonder as to what is the state and safety of that thing......good luck folks.- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
Re: What is it?
Midnightsun wrote:Source of the post Here is an excellent video explaining what an accumulator does.
Thanks for the video.
Re: What is it?
It is a marine unit by the way and the bladder pressure needs to be rechecked at least every year for proper pressure. Just like the tires on your car, rubber is not air tight and does allow air to pass decreasing the pressure with time eventually rendering the unit useless if the pressure is not topped off regularly. Best time would be pre-launch every season. Your unit is most likely 8 litres which is at least 5 times the little plastic ones which all seem to be around 0.75L
Here is a link to a few at Defender. https://www.defender.com/search.html?q=accumulator
Re: What is it?
