Analog to NMEA Engine Data Converter
Re: Analog to NMEA Engine Data Converter
Postby g36 » July 12th, 2022, 2:31 pm
Thanks helmsman. I have spoken with him a couple times very good interactions. Glad your having a positive experience, I just need to let go of some more money :-D
Mikwallace
Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
Has thanked: 117 times
Been thanked: 23 times
Postby Mikwallace » August 9th, 2022, 9:25 am
Enthusiastically following!!
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
JimN
Vessel Info: '89 Carver Santego 38
Been thanked: 3 times
Postby JimN » April 27th, 2023, 11:22 am
This site shows several brands and this is more brands than I have seen in the past.
https://navstore.com/electronics/nmea-d ... nmea-2000/
Mikwallace
Postby Mikwallace » June 29th, 2023, 12:25 am
I ordered the Fox Marine Gateways yesterday. Should have them by the weekend and will become a weekend project. I don’t have a nmea 2000 network and have ordered the stuff to build that also.as of today I dont have the display system so I’ll use the Bluetooth function until I upgrade navionics. Will keep you posted on how this project proceeds.
http://fox-marine.com/index.php?route=p ... duct_id=50
Maybe this link will show the product.
I have some electrical questions about installation but will start a new topic for that.
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Postby g36 » June 29th, 2023, 6:53 am
I answered your other post not knowing what your installing. If your your not going to run a network cable to the helm and If your wanting to control power to the back bone. You could run power from a switch in dc electrical panel that's very easy to get to on a 405 instead of messing with the engine ignition circuit. If like my 405 likely you'll have extra/empty spots on the panel for such.
Hoplite808
Vessel Info: 1988 Carver 3227 Convertible
Been thanked: 8 times
Postby Hoplite808 » June 29th, 2023, 2:06 pm
On my Carver I used the Noland RS11 to convert the analog gauges to digital signals for the chart plotter to read. Installation was easy enough. Just connect a wire to the sender lead on each gauge and then to the RS11 unit. Open up your computer and plug it in then tell the RS11 what it is that it’s trying to read. The software was a bit daunting at first but once I got it set up it worked pretty well. I am kinda curious if the antisense unit is more user friendly but for now the RS11 is good enough for me.
https://nolandeng.com/product/rs11-canb ... converter/
Postby g36 » June 29th, 2023, 4:44 pm
Hoplite808 wrote:Source of the post On my Carver I used the Noland RS11 to convert the analog gauges to digital signals for the chart plotter to read. Installation was easy enough. Just connect a wire to the sender lead on each gauge and then to the RS11 unit. Open up your computer and plug it in then tell the RS11 what it is that it’s trying to read. The software was a bit daunting at first but once I got it set up it worked pretty well. I am kinda curious if the antisense unit is more user friendly but for now the RS11 is good enough for me.
Looks like he posted he has already ordered the fox marine gateways
