Here is a simple way for serpentine tensioning. Welcome to Carver Yachts Owners Forum
Belt replacement
Re: Belt replacement
Here is a simple way for serpentine tensioning. - km1125
I don't like that "belt twist" method because it would also vary by quite a bit depending on if it was a 4, 5 ,6 or 7 rib belt.
There are variations but typically in a v-belt application, you loosen the adjustment nut on the hardware driven by the belt that has an adjustment bracket on it, usually the alternator and raw water pump. This nut will be on a bracket with a curved groove in it. This is used to pull the piece of hardware away in order to stretch the belt when installing or relieve the tension on the belt when removing it. There will also be a bolt to loosen at the pivot point. A bar is typically used against the hardware for leverage to put enough tension on the belt so that there is about 1/2" deflection when you push down the middle of the belt with your finger. When you achieve that tension, tighten the adjusting nut and the pivot nut then run the engine to test.
The only challenging engine I can recall to replace a belt is the 3.0L application where there is an engine mount on the front of the engine that must be removed to get the belt off after removing it from the crank pully.
- Has thanked: 603 times
Ctmangrum wrote:Source of the post So I guess im asking how to get the belt off. On a car, you have the pulley that you can adjust to loosen the belt, take it off, then install the new one. Is there a pulley or flywheel that adjusts for belt removal?
Yes there should be. Take a pic and we will for sure be able to help, it is just a guess at this point.
- Ctmangrum
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
- Ctmangrum
