12 volt interior lights
Bruce
Topic author - Scurvy Dog
- Vessel Info: 1998 3250 aft carver.
- Capt Happy
- Vessel Info: 1974 16 Foot ex DFO Lapstrake Speedboat
1985 21 Foot Baby Cape Islander
1977 26 Foot Trojan F-26 Cruiser
1997 Carver 320 Voyager - Has thanked: 32 times
- Been thanked: 16 times
Are all the interior lights controlled by one switch?
On the Voyager there are four switches for different areas.
I would start by using a multi-meter to confirm power up to the switch.
There are most likely two other reset breakers located around your battery selector switch, confirm one of these have not tripped. You would still have power to your engine and anything connected to this circuit, although the other one may be at fault. If memory serves correct they are probably labeled approx. 25 amp and need to be depressed to reset.
If all good then confirm contacts for light switch are all clean and remain connected.
After verifying power out from the switch, its probably a matter of tracing wires.
Not sure if your manual contains a wiring schematic for lighting or not, but if so it would indicate the first light in the sequence.
Hope this helps somewhat.
cheers
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 29 times
If it's just one section that's affected, then the fault could be anywhere from the breaker in the panel to bulbs in the fixture and everything in between such as switch, wiring, dimmer, etc. Check the easy stuff first like the bulbs. If you're sure they're okay, get a volt meter and check the source side of the on/off light switch. If you have 12 volts there but not on the load side of the switch when it's truned on, then the problem is the switch. You'll have to pick up a ground somewhere to get a reading though as there are usually only positive wires at a switch unless the switch has an indicator light. You can also test the switch by checking continuity with a meter. If you don't have 12 volts on the load side, then the fault is from the switch to the source which could be wiring and panel.
If there's continuity through the switch or 12 volts on the load side, then the problem is after the switch, between there and the light fixture; wiring, ground, fixture, bulb, etc.
Ensure that you have good, clean, tight, corrosion free connections everywhere.
Keep us posted.
Bruce
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
