12 volt verses 120 volt?
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
Re: 12 volt verses 120 volt?
Depending on which model you have, the Norcolds (especially the older ones) actually operate on A.C. whether you provide them with an A.C. source or D.C. source. In some of their power supplies, the A.C. is just converted from 120VAC to 30VAC for the compressor and the D.C. is run through an inverter and converted also to 30VAC. In later models, they converted the 120VAC to 24VDC and the 12VDC to 24VDC, then had one inverter that converted that to 30VAC. The most recent models mostly use a DC variable-speed motor and a small computer to convert either the 120VAC or 12-24VDC to about 12VDC that is fed into a circuit that controls the speed of the compressor.
It sometimes seems a "120VAC fridge" is more efficient or runs better but a lot of that is because it's in an air-conditioned house, not sitting in a boat with the sun beating on it.
Now that all that's been said, you can certainly run a 120VAC fridge on an inverter so you can run it while underway or on batteries. You need to 'upsize' the inverter so it'll handle any surge of starting the compressor but when running it will probably not draw that much more than your Norcold. (most Norcolds use smaller compressors than a "regular" 120V fridge). Not sure what fridge you have in mind but you can take the running specs for it and add about 20% to get a good idea of how much power you'd be drawing from the batteries. If, for example, it's rated at 1 Amp at 120VAC, that'd be about 12 amps running on battery (1*120=120watts divided by 12 volts=10amps then 10*1.2=12Amps). Depending on how hot it is, the fridge might only run 50% of the time (same with Norcold)
One thing you'd really want if you were running an inverter like that would be a settable low-voltage cutoff. Many inverters have this built in, but they're usually too low.... like 10.5 volts. You'd want it to cut off at a much higher voltage...perhaps 11.5 so you don't damage the battery.
- Georgeviking
- Vessel Info: 1995 390 cpmy
1978 32’ Uniflite sport sedan
1968 31’ ulrichsun
1968 31’ broad water
1977 19’ checkmate
1975 17’ west wind. - Location: Strong Island N,Y
- Has thanked: 4 times
- Been thanked: 3 times
