AC not working well
- BRHEAUME
- Vessel Info: 1995 Carver 355
- Has thanked: 11 times
AC not working well
I have a 355 Motor Yacht. Two AC units, forward is 16,000 BTU, rear is 12,000 BTU. I find that the velocity of air out of the registers is not strong at all. The air that is coming out is cold (going to verify temp with infrared thermometer) but it just doesn't seem to have enough air pressure (similar to having the AC in your car on the lowest fan setting). Is this normal? I've checked the screens, coils (cleaned both) and can't seem to get the AC performing well. (only a 5-10 degree drop from outside temperatures in the cabin)
- Has thanked: 602 times
Re: AC not working well
How is the water flow? At 300 gal/hr (which might be true flow with a "500GPH" pump but going through restrictions of heat exchangers), that's only about a 10 degree temperature difference from input water supply (lake temperature) to outlet temperature. When you check the indoor air temps with the IR gun, also try and get a reading of the temp of the outflowing water as well as the actual local water temp. If you're flowing 300 GPH, then every ONE degree of water temp change is about 2,400 BTU, so if you're off be just a few degrees in the water temp rise it affects the overall capacity of your HVAC systems.
- BRHEAUME
That being said, if vents are blocked substantially and you are not getting enough air through, the unit will normally frost up on you which may be the case. Have you physically looked the units heat exchanger? The thing that looks like a radiator on a car? It may very well be all frosted up blocking your air flow.
I always clean the filter screens on my units at least once every summer as part of general things to do on board before my first beer that is.
Verify that first...
- BRHEAUME
Have you been thru a summer with your boat yet, is this a new issue ?
Viper wrote:Source of the post Make sure you don't have them set to a slow fan speed at your control panels.
This is a good point.
Which controls do you have?? On some you have to go into the settings mode to select the default or max fan speed.
