Cockpit vinyl panels on 350 Mariner
Topic author
docbob3704
Vessel Info: 2002 350 Mariner with 3.5 Volvo pentas. Lake Erie, Niagara River, Buffalo NY
1st Carver
Postby docbob3704 » January 26th, 2016, 7:13 pm
Has anybody removed the vinyl padding around the cockpit of a 2002 350 mariner? Mine are looking a little worn and I want to reupholster them.
Ramsport47
Been thanked: 59 times
Postby Ramsport47 » January 27th, 2016, 6:18 am
We have removed them at work. There should be two screws under each one that hold them down and a snap at the front, then they lift straight up off of aluminum brackets.
Kenny
T-Merc 350 Mag MPI (300hp)
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Postby Agriman » January 27th, 2016, 11:06 am
I removed ours on our 1998 Mariner and the padding across the back is a little snug to get a screwdriver under at the end where it attaches above the bilge vents but with an extra long Philips screw driver you can do it. The shop charged me $300.00 to redo in heavy white vinyl material. I replaced the air duct vents when I had the pads off with 4 inch plastic vents from H.D.
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Postby SplashyLady » January 29th, 2016, 10:39 am
Are you talking about the coaming bolsters/pads? Most of these are made by Garelick and you can find replacements at marine outlets/salvage or on eBay. Seadek makes a newer version as well that some folks really like. They come in standard sizes (usually 36 or 48) and you can bend them around curves if needed.
http://www.ebay.com/sch/i.html?_odkw=co ... r&_sacat=0
You can get the old ones recovered, but make sure the upholsterer uses marine grade materials! Sometimes it's less expensive to buy new ones than to get the old ones re-done. Good luck!
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
