Starlink Portability
Re: Starlink Portability
The really cool part is where he describes how to delete the big, power hungry and limited Starlink router to use a conventional router and POE injection to power the dish using 12v as opposed to 120v. This guy is pretty amazing if you ask me.
Looks like I may have found another project as I already had decided to remove my Intellian dish which will give me room to mount the Starlink in a more professional and permanent manner.
Why would you want to go this route? You will now run only 1 modem which will cut down power usage quite a bit and you will have a failover function to supplement Starlink for a reliable connection almost all the time. all wifi will be operated from 12vdc as opposed to 110v inverter power which also saves on power consumption.
This also seems to be a nice modification to get the Starlink RV into a small flat package which is much more convenient on most boats. Needless to say, once you mod your dish the warranty is gone. https://star-mountsystems.com/products/ ... link-dishy
Starlink does now offer a in-motion flat dish however they want 2,500 US for it and it does draw about 3 times as much as the RV dish when it comes to power consumption. Not really interested in this option as it is also quite a bit bigger in size. https://www.starlinkhardware.com/starli ... otion-use/
- Been thanked: 654 times
I did order one of these and will be using it for a full conversion to 12VDC for Starlink. Tested out the the Peplink router yesterday. Works great with the failover feature I previously mentioned so any Starlink dropouts are seamlessly covered by my Cellular plan which would be next to nothing in terms of data since the dropouts are rather small lasting usually seconds. Or if the boat was to be under a cover then Cell data would cover the missing data.
