1993 359 Motoryacht windows
Topic author
Barefootin
Vessel Info: 1993 Carver 350 Motoryacht
Postby Barefootin » February 6th, 2016, 4:39 pm
Can anyone help with how to remove the salon widows from a 1993 carver 350 Motoryacht
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: 1993 359 Motoryacht windows
Postby Lyndon670 » February 12th, 2016, 11:36 pm
If you are talking about the front windows, I would imagine that they are simply glued in like they are on the newer models (like mine). Work a butter knife in behind one and pass some piano wire from the outside through to the inside and work it around the frame. You can get the glue from an automotive store to reseal. I had to do one on my 93 41C Silverton a few years back.
The side salon windows will need the trim panel around them to be removed and then the same process to remove them (if they are sealed and not the sliding type). If they are on the slides, lifting an tilting them should get them out.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
