466 fuel vent hose 2001
- rfverdery
- Vessel Info: 2001 Carver 466. Twin TAMD 74 P 480 Volvo’s.
- Has thanked: 26 times
- Been thanked: 2 times
Re: 466 fuel vent hose 2001
It is common practice to put a loop in the vent line. Every time it spurts fuel upon fill up, the bottom of the loop replenishes with some gas. If the leak is in the loop bottom, then yes it will drip out. Most likely the case as todays ethanol fuels eat away at older non ethanol compatible rubber and since fuel sits in the loop it will occur there first. This is what a fuel vent loop looks like. https://www.sailnet.com/threads/why-is- ... 80&slide=0
Had this very problem on my previous 1997 boat however it was the fill line that got eaten away from the inside out. Should not happen but when you add a solvent that eats rubber to your line this will happen. Ethanol was a huge F up IMHO not to mention it must have caused billions of dollars in damage over the years wherever gasoline is used.
Unfortunately I don't recall where the access points are to get to the vent fitting from inside.
- rfverdery
- Has thanked: 602 times
This is a diesel, so it may just be a restricted vent and a loose fitting.....hopefully.
- rfverdery
rfverdery wrote:Source of the post Now that I think about it I believe it was a vacuum. Does that mean something different?
Still means a plugged vent. Shouldn't have pressure or vacuum in the tank.
A plugged vent and a vacuum could actually collapse a tank. All depends on how good the fuel pump is and if it can still deliver fuel to the engine under that kind of a vacuum. On a gas engine with electric pumps the engine would probably starve first.
Ya check your venting system. If there was a vacuum, it's likely blocked. It's strange though that there would be a vacuum in a system that's leaking. You'd think with a leaking hose that pressures would eventually equalize through the hose at the leak even if the vent was blocked.
