‘89 Santego 27’ - 1st Big Boat Project
Re: ‘89 Santego 27’ - 1st Big Boat Project
- Creek_Cruiser27
- Vessel Info: 1989 Carver 3807 Aft-Cabin,
1989 Carver 2767 Santego Mid-Cabin - Location: VA, USA
- Has thanked: 20 times
- Been thanked: 2 times
1989 Carver 3807 Aft-Cabin, Twin 8.2L Gas Inboard Mercruisers.- Creek_Cruiser27
I was going to use my existing OD’s if I only had to replace one transom, but two… Forget that. Fortunately, the good news is that both engines checked out fine with one only needing a new starter and water pump. Since both transoms had to come off I called up SEI and got a great deal on two A1G2 setups from the transoms back. Both complete A1G2 sides cost me $1200 less than both the A1G1 transoms alone.. Decided to keep both sides RH as I already have 4 RH props (and also because I forgot to specify counter rotating before the new units shipped
) . So I got good engines out and in and a whole new back end (with no-fault 3 Yr warranty) for under 12K so far. So, yeah, bad luck/good luck but still she’s shaping up nicely and glad the engines are GTG!
1989 Carver 3807 Aft-Cabin, Twin 8.2L Gas Inboard Mercruisers.- km1125
Bit surprised on the "counter rotating" issue. I thought that was just a matter of the linkage and the props, but I don't know outdrives all that well.
You're not concerned with handling issues with the props all going the same way?
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Creek_Cruiser27
Looking for input. I need to replace the anchor line. I think it had 1/2 x 150 before (swollen and mildewed so hard to tell). Is 1/2 x 200 overkill for this boat? Will 3/8 work? Also looking at double braided vs wrapped lines. Will MFP do or should I go with Nylon? Will probably see mild use bit mostly in salt water. Suggestions?
1989 Carver 3807 Aft-Cabin, Twin 8.2L Gas Inboard Mercruisers.Return to “Introduce Yourself!”
