Hot Water Heater Drain
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
On my 2005 Mariner there is a thru hull 'drain' for the hot water heater.
Does anyone know how to have the unit drain through that plumbing? It's there, I just can't figure out what combination of 'valves' leading into the heater will make it happen.
in the past I simply open the spigot on the heater, lift the pressure release and the water flows onto the deck.
It would be nice to use it as designed but don't know how.
Thanks.
Re: Hot Water Heater Drain
Thats how it is supposed to be done, nothing more. It can happen that deposits start to plug the drain hole so you may need to remove the valve and run a wire in there to flush out the crud a little. Obviously take care to do this when the heater has been off for quite some time to avoid burning your hands.
- denpooch
It's odd because a diagram in the owners manual details 'water heater drain'.
I wonder if it has to do with a specific combination of the three 'on-off' valves. There is the cold water 'into' the unit. A hot water 'out' and also a 'bypass' valve which I turn on when draining the heater. This bypass allow me to get by using just a couple of gallons of pink instead of filling up the heater.
Thanks for your input.
denpooch wrote:Source of the post Hans there is no drain hole. The water just runs forward on the deck and into the sea.
The 3 valve bypass is rather common on most boats however this will not drain the heater and is used exactly as you described to bypass the water heater when introducing antifreeze. How are you draining the water heater with no drain? Not following you on the "water just runs forward on the deck and into the sea".
- denpooch
The water heater is forward behind the 'rumble seat' on the bow of the boat. When I open the spigot and release the pressure valve, the water runs forward (Mariners list slightly forward due to 150 foot chain in the anchor locker)
and 'off the boat'.
Thanks to you and Viper. I will proceed as usual.
- Has thanked: 603 times
Yes there is no way the water would drain anywhere but down the deck to the bow considering the deck slope.
- denpooch
Open the spigot...release pressure valve and walk away.
Bypass the heater, add 2 gals of pink into fresh water system, run pink out of each faucet. Force pink thru 'city water' input and the fresh water system is ready fo hibernation.
Ran fresh water through A/C system. Forced pink til it came out of both thru hulls and done.
Engines this weekend.
Thanks again guys.
I forgot to bring the drill pump and was stuck so my tiny little brain had to work a bit.
It was so obvious I guess I never thought of it, KISS. While introducing pink into my wash down via the on board wash down pump, I simply connected the wash down spigot outlet with a hose to the city water input. Why in the world did I never think of this before, so easy. In my case the wash down outlet and city water inlet are only a few feet apart, easy peasy.- bud37
What ever little organisms are swimming around in the raw water side you will introduce to your fresh water side by pumping this way.......we never used our fresh water system for drinking even though it was sanitized in the spring at start up.....so be aware. If unsure, a fresh water test sample can be taken and analyzed to ensure safety.
Users browsing this forum: Google [Bot] and 42 guests
