Trim Tabs Reservoir Location?
mphillmd
Topic author - Scurvy Dog
- Vessel Info: 2003 Carver 444
I'm new to this site. I have a 2003 Carver 444. Trying to locate the reservoir for the trim tabs. Owners manual no help. Anyone know where to find it? Thank you.
Mike
- Wayne162
- Captain
"Change In Latitude"
Home port - Charleston, South Carolina - Has thanked: 16 times
- Been thanked: 32 times
- Contact:
Re: Trim Tabs Reservoir Location?
Belated welcome, if your still looking for your trim tab reservoir try looking Aft. I have a 1997 405 and I located mine under the bed in the Aft cabin. I looked through a floor panel and found it mounted directly beneath the Starboard side of the headboard against the Aft bulkhead. Mine used Tran fluid to fill.
- Been thanked: 490 times
Hope you are still around.
waybomb wrote:Wow, I missed this first and only post by mphillmd.
Ya how did we miss this one?
As noted above, they are typically mounted close to or directly to the transom. Here is a link to a picture:
http://www.westmarine.com/buy/bennett-marine--12v-hydraulic-power-unit-with-pump-valves-reservoir-cover--264044
Sorry for the delayed replies Mike, this is not the norm here. Usually we're on it right away but I don't recall seeing this one.
