AlexB wrote:Source of the post A new issue I just learned of. Apparently last year the mechanics on the marina used 10w-30 oil when on the engines it says to use SAE40. Would that cause problems? Does this mean I have to use 10w-30 when I do an oil change now?
Also what oil would you recommend for my crusaders?
Thank you everyone for all the advice.
IMO....You can be confident to just change the oil and filters and use whatever oil you want.....try to stick with the recommended oil for your engines.
The "W" part of the oil designation is basically for the ambient temps the engine starts up at, once the engine is running and warming up, the oil begins ( as I am given to understand ) to act as the thicker number at around 100 degrees oil temp not ambient.
Once past that point the engine oil does not care what temp it is outside. In cold climates starting an engine with a sump full of 30wt, 40wt or 50wt oil would require a serious battery and starter, and the engine would not get proper oiling for a while due to pumping issues......
We ( boaters ) really don't have that problem for the most part......
