SF bay area new Carver Owner
BoyAndSea
Vessel Info: 1986 Carver Santa Cruz 2667
--I'm in San Francisco, CA
--master mechanic
--plan to help others and show (real) how-to steps along the way
Postby BoyAndSea » October 29th, 2022, 4:56 pm
Greetings!
I now own a 1986 Carver Santa Cruz 2667 w/ the Mercruiser 260 and Alpha 1 gen 1 Outdrive.
I'm a master mechanic who loves fishing the California coast, and am currently getting my Carver in "ship shape" before it's maiden voyage. Previous owner seemed a little "adventurous" and removed the upper flybridge!! I actually think it'll be worthwhile to use the flat roof for fishing things...
Couple things that I'm currently fixing:
--Trim/tilt leak
--took apart, discovered cracked reservoir, I'll take that easy one all day!
--Steering Helm leak-- Found bad seals, possibly b/c previous owner used incorrect fluid and swelled seals
--Likely will need to rebuild carburetor, we shall see when I go to fire it up
Been thanked: 470 times
Re: SF bay area new Carver Owner
Postby RGrew176 » October 29th, 2022, 9:54 pm
Looks pretty good for an old girl. Good luck getting here shipshape. Hope you have many fine adventures aboard.
Postby Viper » October 29th, 2022, 10:48 pm
Welcome aboard
Postby km1125 » October 30th, 2022, 10:30 am
Welcome aboard!! Looking forward to seeing the projects and the pics!
BoyAndSea
--master mechanic
Postby BoyAndSea » October 30th, 2022, 3:11 pm
Thanks, all. I'm looking forward to it as well. This boat will require much more work than any of my previous vessels :confused: . Challenge accepted!
Earlier today I found the lower transom bolts are corroded pretty bad, probably going to require me to pull the engine and transom assembly unfortunately :banghead: ...may not have a maiden voyage for awhile...LoL
Been thanked: 491 times
Postby waybomb » October 30th, 2022, 4:16 pm
Maybe they hit a short bridge?
Welcome aboard!
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » October 31st, 2022, 11:03 am
At least you're going to get a good look around that bidge! If that Alpha One outdrive needs any significant repair, just get a new drive. They are very reasonably priced. Welcome to the gang! You and Viper are going to be good friends! 8-) er
Cooler By The Lake
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » November 1st, 2022, 6:07 am
Welcome!!!!!!!!!!
