Phrancus wrote:Source of the post .....
Bottom line: draining a starter battery over 50% causes damage and becomes dangerous. Use a house battery to avoid that from happening.
There's nothing magic about the 50% mark. Any lead-acid battery likes to be fully charged. Running them down decreases their life and it's almost a linear scale. The 50% mark is used as an economic balance between useful life and capacity. There are plenty of charts available from manufacturers on depth-of-discharge (DOD) vs "cycle life", which is the number of times that battery can be expected to preform reasonably while being discharged to that percentage. If you look up those charts, you won't see any significant change from 40-60%, just a continuation of the same line from 10-90%.
Since a starting battery typically has a smaller AH capacity than a deep cycle, then draining the same amount from each would result in a much larger percentage from the starting battery. However, if you used two batteries with the same AH capacity, then you could draw the same percentage of each and get very similar life out of both of them.
