Onan MCCK 6.5KW GenSet project on 1984 3697 Mariner
rictamily
Vessel Info: 1984 mariner 3697
Has thanked: 14 times
Been thanked: 2 times
Postby rictamily » December 14th, 2022, 4:12 pm
Hello all,
Just wanted to show some before and after progress of the current generator rebuild. Got spare parts from a couple of places. One is from a guy in Florida who has thousands of Onan MCCK parts if anyone is interested in contacting him.
Re: Onan MCCK 6.5KW GenSet project on 1984 3697 Mariner
Postby km1125 » December 14th, 2022, 5:00 pm
Interesting!! Post up some more pics! The genset looks nice cleaned up like that!
Postby Viper » December 14th, 2022, 5:58 pm
She looks great. What spec is she? Did you inspect the exhaust nipple between the manifold and the elbow before putting everything back together? Those were known to corrode from the inside out and were the cause CO poisoning that resulted in lawsuits. The replacement nipples were stainless steel.
rictamily
Postby rictamily » December 14th, 2022, 8:24 pm
Viper wrote:Source of the post She looks great. What spec is she? Did you inspect the exhaust nipple between the manifold and the elbow before putting everything back together? Those were known to corrode from the inside out and were the cause CO poisoning that resulted in lawsuits. The replacement nipples were stainless steel.
Thank you. I definitely need to look into the exhaust nipple. Are you referring to number 12 on this screenshot from the manual?
The specs are the following.
model/ spec number is 6.5 mcck - 3cr/1h
Class= F
PF=10
PH=1
HZ=60
RPM=1800
KVA=6.5
Postby Viper » December 14th, 2022, 9:14 pm
Yes it's #12 in the parts breakdown but I would also check #11 and the elbow (10?). You may need to apply heat to remove the nipple if it's original. You want to be careful not to break the threads off in the manifold or the elbow.
The spec ID is usually a letter. Don't know if the "class" is the same as the spec ID. Your manual should mention something about the different spec IDs
Postby g36 » December 14th, 2022, 9:30 pm
Looks good I'm sure you'll be happy getting her back in t he boat
