Cutlass bearing replacement determination - 1984 Mariner 3697
- rictamily
- Vessel Info: 1984 mariner 3697
- Has thanked: 14 times
- Been thanked: 2 times
My prop shaft is 1 ⅜ diameter. I have the boat on blocks so wanting to do maintenance while on the hard. The props are removed and when shaking prop shafts there is movement...movement enough to make a slight clunking sound when emphasized. Is there a certain tolerance?
Also, is the process of replacement just a cutlass bearing-removing tool to remove and replace? Or are other calibration methods required?
- Has thanked: 603 times
Re: Cutlass bearing replacement determination - 1984 Mariner 3697
https://www.pacificmarine.net/engineeri ... arance.htm
- rictamily
Users browsing this forum: No registered users and 37 guests
