Cabin door, Carver 406
Chat with fellow Carver owners about cruising destinations and more. Plan rendezvous, raft ups & get together's here.
1095063lf
Vessel Info: Carver 406 aft cabin, Cummins power, loop veteran
Postby 1095063lf » November 29th, 2020, 5:42 pm
My mechanism for opening the cabin door need help, I am trying to find the mfg of the door lock and hatch release, If you dont have a Carver that opens the door and hatch at the same time you likely dont understand the problem.
Re: Cabin door, Carver 406
Postby g36 » November 29th, 2020, 7:44 pm
If your talking from sundeck into boat cabin.. My 405 which is the same boat has a perko lock like this one for the entrance . https://www.boatid.com/perko/mortise-lo ... 0MEALw_wcB
bug guy
Vessel Info: 2000 Carver 405 aft cabin and twin diesels
Postby bug guy » April 10th, 2022, 9:38 am
I am looking for the same type of lock for my 200 405. The doors close and the hatch comes down over the top of the doors. There is a lock/ closing mechanism on the latch that I need to replace. Any ideas. Did you find parts for yours
Postby km1125 » April 10th, 2022, 11:03 am
g36 wrote:Source of the post If your talking from sundeck into boat cabin.. My 405 which is the same boat has a perko lock like this one for the entrance . https://www.boatid.com/perko/mortise-lo ... 0MEALw_wcB
If anyone just needs some parts for one of these latches/locks, let me know. I think I have an older one in the basement.
Mikwallace
Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
Has thanked: 117 times
Been thanked: 23 times
Postby Mikwallace » October 12th, 2022, 2:05 am
Bringing this thread back to the top. I’m looking for the Hatch “Spring” type locking cylinder. I’ll take a picture tomorrow and post. Mine is bent and I’m not sure it’ll bend back in position without breaking.
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Mikwallace
Postby Mikwallace » January 13th, 2023, 12:50 am
Mikwallace wrote:Source of the post Bringing this thread back to the top. I’m looking for the Hatch “Spring” type locking cylinder. I’ll take a picture tomorrow and post. Mine is bent and I’m not sure it’ll bend back in position without breaking.
I finally got around to posting the picture. You can see where it’s bent and disconnected from the hatch. The bent arm is circled in yellow.
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Postby km1125 » January 13th, 2023, 9:29 am
I'd bet you could take that apart and have that rod straightened, or even just replaced.
It might be possible to replace both of those with small gas struts too, but then you wouldn't have the adjustment. They would keep the hatch all the way open though.
Or- rethinking that... you might even be able to replace just the right side with a gas strut, and still be able to use the left side as the adjustment!
Return to “Boating & Cruising Lifesyle”
