1998 405 Aft Cabin Window Replacement
- Been thanked: 654 times
Re: 1998 405 Aft Cabin Window Replacement
- Rpanerali
- benica
- Vessel Info: 1997 355 Aft cabin. 7.4 engines.
- Has thanked: 1 time
- Been thanked: 9 times
Appreciate the potential help.
1997 355.
Aft cabin rear window removal help ... please
Above the storage locker in the swim deck..the window.
Removed all the screws from the frame....and thinking..that frame should just...pull off. Didn't. Went inside the cabin...removed the sliding window...looking for other.. fasteners perhaps. Seen none. Reinstalled the screws and now asking... .
Do I need to force the frame off? Perhaps use a tool to get behind the metal frame and window and work the frame off?
I don't want to do the wrong thing and potentially causing damage...
I'll be removing, repairs and revealing the aft cabin windows.
Water leak...port side rear corner area and port side....along the ceiling fabric seams near the storage bin...this particular leak...can't be from the window..
WIndow is below the ceiling...so...thinking...coming from the "Wet Bar?" Or the drain hole behind the wet bar/sliding cabin door.
- Has thanked: 603 times
benica wrote:Source of the post WIndow is below the ceiling...so...thinking...coming from the "Wet Bar?" Or the drain hole behind the wet bar/sliding cabin door.
Don't forget about the stanchion posts mounted to the deck above the window area, also the roof supports etc.....all things to inspect for possible reseal/rebed.
Hopefully someone with a 355 can definitively answer your window question, my guess would be, it is stuck with sealant/adhesive, but don't take my word.
bud37 wrote:Source of the postbenica wrote:Source of the post WIndow is below the ceiling...so...thinking...coming from the "Wet Bar?" Or the drain hole behind the wet bar/sliding cabin door.
And don't forget to check things like cleats. I had a similar situation and blamed it on the starboard ports in the aft cabin, and it ended up being water getting in under the cleat and running down inside the hull.
- Rich W
- Vessel Info: 1993 350 Aft Cabin
Sandy's Riches - Location: Upstate New York
- Been thanked: 3 times
Users browsing this forum: Google Adsense [Bot] and 23 guests
