Boat will not steer, wheel spins freely
decker19
Topic author - Scurvy Dog
- Vessel Info: 94 mariner 330
Mkemper
- Vessel Info: 86' carver 3207 Aft
[IMG]http://i1238.photobucket.com/albums/ff498/mjkkemper/null_zps98e8d64b.jpg[/IMG] - Been thanked: 8 times
Re: Boat will not steer, wheel spins freely
Not sure if I am breaking any rules but below is a link in case you have a leaky seal and need to rebuild.
You should have a reservoir with a pressure gauge on it. If it reads zero that you have lost pressure
http://www.lakestclair.net/index.php?/t ... try1172041
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
SeaDragon
decker19
Aahub - is the master cylinder in the bilge where the lines connect to the metal arm behind the drives or is it under the helm? Im assuming it would be near drives in bilge.
Thanks,
Chad
- Been thanked: 490 times
You can read up all about them on the Teleflex website.
Your steering wheels is attached to the "pump". The pump creates flow as you turn the wheel, and directs fluid through hoses/lines to your steering cylinder, which is connected to the shaft connecting the rudders. In between, or ancillary to the pump and the cylinder is a reservoir. The reservoir has either a site gauge or is opaque so fluid level can be determined. It also has a pressure gauge on it. If the reservoir has a fluid level in between the two marks, and the pressure gauge is reading some amount of pressure, you have no leak. No pressure and/or low fluid, you have a leak. Depending on the syste,m you have the reservoir will have a capacity of one or two quarts.
The pump probably has three lines running into it. One is for port steering, one is for starboard steering, and the one in the middle is from the reservoir.
Your steering cylinder has the other two lines connected to it.
The steering lines <may> pass through a relief valve mounted underneath the reservoir.
If you have determined you have a leak, you will find it by simply following the lines. The line will have oil all over it and probably a puddle of oil below it in the bilge.
If you have determined you have no leak, and you have no steering, then either the internal pump seal(s) have failed, and/or the steering cylinder has failed seal(s) in it.
If you can determine what model pump you have (it is noted on a tag on the pump), then you can search the Teleflex webpage for a better description.
Let us know what you find.
decker19
I checked the gauge and it reads 12psi which seems to be lower than recommended level but still not at 0. Looks like label said it should be at 30
The fluid level is hard to tell. To me it looks like it is all the way full as the little glass bubbles to look at fluid levels is a solid color of medium brown so Im thinking the fluid is completely full. All the cables appear to be attached. (I also discovered an unrelated leak while scurrying about in the bilge on my starboard engine water pump which I will be posting about later on another thread as detailed out on forum etiquite)
My next step it sounds like is to check the seals and pump cylinder. This may bring me back to a previous post about Wiper seal too.
I did check everywhere I could ot see if there was a small puddle of fluid anywhere and there did not appear to be much fluid excdept a little water and gunk. A good reason for me to clean it up to amke diagnosis easier!
I'll post when I get an email back (hopefully) from Seastar and I am also working on finding a tech who can help at the marina as this may be getting over my head in abilities.
There must be an internal seal leak, or possibly the relief valve is stuck open.
strokerking
- Vessel Info: 1981 Carver Aft Cabin
IF you have a reservoir system, it would be someplace accessible. Follow the lines either from the helm to the steering cylinder at the back of the bilge, or follow the lines the other way. I would guess your reservoir is in the bilge near the cylinder. But I do not know that for a fact.
If the helm only has two hoses, then the helm unit is the reservoir, and there should be a cap at the top of it, usually visible from your chair. You simply remove the cap and fill it. You shouldn't to fill it unless you have a leak.
strokerking
Users browsing this forum: KyleR and 35 guests
