On-board Battery Charger with Generator and Engines Running
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
So here’s the question:
Should I turn off the On-board battery charger, if the generator and engines are running to prevent both Alternator and battery charger operating simultaneously?
Maybe I’m overthinking this? But it’s all still new to me!
1979 Caravelle 18’
Re: On-board Battery Charger with Generator and Engines Running
However, I don’t believe the opposite battery bank (selector position 1 versus 2) is being charged by the engine alternators. Only the battery bank that’s selected.
This is normally how it works on boats with 1/2/both selector switches unless there is some type of ACR or battery combiner installed somewhere which will connect as required. Regardless, no need to shut down the on board charger in any condition.
Which batteries get charged while the engines are running really depends on how she's wired. Some were wired such that they only charge the bank the battery selector switch is set to while others were set up with devices such as ACRs, combiners, isolators, etc., allowing all banks to be charged by both alternators regardless of the selector switch position. The key is that the banks remain isolated from each other when not combined for charging purposes.
Follow the large charge wire (usually orange) from the alternator, if it goes to the starter, it will charge the battery/bank that the selector switch is set to. If the charge wire leads away from the engine, it's likely heading to a charge distribution device. A lot of builds used a battery isolator back then; a rectangular metal box with cooling fins, and terminal posts. They allow one or both alternators to charge all the banks but the diodes act as a check valve and prevent electricity from flowing in the opposite direction thereby isolating each bank.
- Has thanked: 603 times
Mikwallace wrote:Source of the post Should I turn off the On-board battery charger, if the generator and engines are running to prevent both Alternator and battery charger operating simultaneously?
If that is a concern for you, simply shut off the charger and move the switch to both....that way the engines will take care of the bank charging while underway......engine alternator systems are designed for this type of service.
I just think there is nothing wrong with hands on and being aware of how you operate your boat....considering that your life may depend on the correct operation.
That said, I do like all that electronic stuff to do this for you, just not for me for the reasons given above....+ cost.
Therein lies the problem. The fact of the matter is that people forget to do just that. Considering it's such an issue and that there are other more reliable ways of accomplishing the same thing without having to remember anything, I fail to see why OEMs are still on the path of using selector switches. I can tell you that 95% of boats that I go on at their slip still have their switches on ALL/BOTH. Of coarse they'll also have their chargers on. This combination is a good way to fry your batteries and it really does make having a multi bank charger pointless.bud37 wrote:Source of the post ....only takes a few seconds to operate a few switches,....
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
The voltage regulator will supply enough regulated power when running some rpm's but when it drops to idle, the battery is supposed to work like a temporary source of power to keep it running. Not all (most not) regulators/alternators are designed to not fail when there is nothing to regulate. Not sure how it works when your battery fails while running the engine though.
Anyway, don't go flicking that main switch with the engines running untill you are sure that it's not going to break expensive things.
