Best bedding compound
Dad Joke
Vessel Info: None yet
Been thanked: 3 times
Postby Dad Joke » February 16th, 2023, 1:45 pm
I like Sikaflex 291 better than 4200. My question is, how difficult is it to remove 291 when it comes time to re-bed? Thanks.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Re: Best bedding compound
Postby tonyiiiafl » February 17th, 2023, 6:49 pm
Was just going to ask that. I am replacing the opening porthole oval windows at the bow of my 390 with fixed portholes. Non opening. What would you use?
Hold'n On II
Vessel Info: New to us 1996 370 Voyager
Been thanked: 11 times
Postby Hold'n On II » March 3rd, 2023, 10:37 pm
Allot depends on how much material is between the surfaces being bonded. The more compound there is the better the chance of the compound tearing/separating when trying to pry them apart, but it's also more elastic, which requires more force, or cutting to separate. If the compound is thin and the adhesion strong, there's a chance it'll pull gel coat off with it. Most all of the advanced compounds these days have pretty substantial adhesion. It's the UV and durability that makes the difference.
I've found that an oscillating plunge tool with a scraper blade will make quick work of most anything Sealant/Adhesive related, provided you can get the tool into the area your working on. Once the surfaces are separated, I use a razor blade and an appropriate solvent to remove whatever is left.
I used Sikaflex 295UV when I re-bed the port side salon window on our '96 370 Voyager and will be re-bedding the starboard side this spring.
Users browsing this forum: Google [Bot] and 25 guests
