Improved water pump w/Relay
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
http://www.argonsailing.com/2016/02/water-water-everywhere-but-i-cant-flush.html?m=1
1988 Carver
3867 Santego
PCYC
Re: Improved water pump w/Relay
I also have another failsafe which is to switch over to "river water" which uses the wash down pump to pressurise the water system using lake/river water. This was a mod I did a few years back which can be seen here. Long read but really a great modification assuming you boat in fresh clean water. viewtopic.php?f=13&t=3204&p=21171&hilit=river+water#p21171
- Has thanked: 602 times
Viper wrote:Source of the post In my personal experience though, a freshwater pump failure has rarely been due to the pressure switch.
This was my point about getting another model/brand of pump as opposed to trying to fix a poorly engineered one.
I agree. I like the mod though, it's thinking out of the box. Those relays are great for countless applications. KM's suggestion of using a capacitor is also a good way to help reduce arcing.Midnightsun wrote:Source of the postViper wrote:Source of the post In my personal experience though, a freshwater pump failure has rarely been due to the pressure switch.
I think that is a major problem nowadays, considering where all these parts come from in the first place. Just how can you figure out the quality of internal workings when many engineering decisions are made by bean counters and bonus plans.
I have tried over the last 10 years to buy North American made, it is very hard as some products appear ok on the surface but on inspection the parts come from all over, once again leaving them open to the cheap acquisition rule.
That faulty switch is the perfect example, for a few cents more it would probably be fine.
Darn shame IMO.
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
vineyardgray wrote:Source of the post Found this blog post of great interest, l thought I'd share:
This might be a bit of an overkill? However, I did this setup in my RV and it’s made a significant improvement in my fresh water system. I already had the relay, ordered the Accumulator from Amazon, picked up a couple SS hoses from Lowe’s and 30 min later it’s working. Now the pump is quieter and it seems to operate smothrt
1979 Caravelle 18’
