Nuteak
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Nuteak
https://nuteakontario.ca/
Re: Nuteak
Thanks for the post, always nice to see new products.
- pepmyster
8.1 Volvo Penta
Re: Nuteak
Re: Nuteak
I've never had to remove Nuteak before so I can't comment on the ease of getting rid of the glue typically used. I guess that's an indication of how long the product lasts, and it's been out for quite a while now. The glue isn't infallible though and can lift in some spots but unlike Seadek, you can correct these areas without ruining the flooring. There are spray products out there now that can lift all types of caulking and glues by just spraying the affected areas if it ever came time to do a major replacement. I have on the other hand removed Seadek and if you really wanted to go back to the original gel surface, it's totally doable. The glue will come off with elbow grease and a lot of acetone. It's messy and time consuming but it can be done.
