8.1 Crusader water reverion, ingestion.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
Re: 8.1 Crusader water reverion, ingestion.
I have read a lot of articles regarding water reversion and ingestion or condesation in the risers/elbows and it seems there is no cure if you you have this problem. I own a Carver 396 Aft cabin that iIthink has this problem.
The engines are 2008 with 535 hours and 1 cylinder in not firing. The ECM did not show an error codes.
The mechanic was able to determine #7 cylinder was not firng. I guess the next step is a compresion test.
Anyway, these engine have 4" risers and it looks lihe a standard Crusder elbows. If i do a valve job am I doomed to
have history repeat itself? Did the original engines have risers or just elbows? Were 4" risers in this engines originally?
Your comments would be appreciated.
If you think you're getting reversion, you can try installing Mercruiser resonators inside the exhaust hoses just after the elbows. This helps minimize the effects of valve overlap in the exhaust which leads to reversion. It may also help reduce ingestion. There are in-line exhaust check valves to prevent ingestion or you can install flaps on the hull exhaust ports if your style of ports allow. What kind of mufflers do you have, lift mufflers?
Whether risers are used really depends on the geometry of the engine install and hull design. There is a minimum height spec from the top of the elbows to the water line. If I recall, I think it's at least 13" or so. If the elbows don't reach that height, risers are installed to raise them above that minimum spec. A member with the same model year and engine package may be able to help and let you know whether theirs has risers or not.
It would help to know which model you have. When the tech says #7 isn't firing, I'm assuming he's determined the ignition system is working fine, and that #7 spark plug is firing but the cylinder isn't firing, correct?
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
{{Plan on immediately replacing elbows and risers on both engines. Do not run another season.}} Pull all plugs to compare condition. Is the #7 cyl. plug wet, oily, damaged? Then do a compression test, should be 125-150 psi or so. If uniform, replace plugs, cap and rotor and use a timing light on each plug to see if all are steady flashing while at idle. If #7 is dead look into your ignition system.
My '92 is carbureted, so I am not up on later fuel systems. Is the 2008 MPI? if so an injector could be bad. Try replacing that.
These tests should indicate the type and source of your malfunction. If you are having a mechanic work on this, make sure the he follows a sequential troubleshooting procedure....not just " Ahhh, #7's out, pull the heads"!
Post your findings. I'm sure much more advice is out there!
Phil Little
'92 3307 Aft Cabin
- Has thanked: 603 times
https://www.cpperformance.com/t-what_is ... rsion.aspx
