2004 360 Sport Sedan questions
FlightPayIV
Vessel Info: 2003 Carver 360 SS
Has thanked: 2 times
Re: 2004 360 Sport Sedan questions
Postby FlightPayIV » March 1st, 2023, 5:10 pm
bowfirer wrote:Source of the post Just went through the stalling issue with the port engine as we were lining up with the slip. Oh, just great! Anyway, turns out the batteries were shot and the alternator could not keep up with the electrical demand. Replaced the batteries; all fixed. This is a 2005 Carver 360 Sport Sedan. One other thing: if you want to replace the shore power cables be prepared to spend some $$$. Carver, in their infinite marine wisdom, decided to hard wire the original cable to the midship panel. Yes, really, they did. So, I had to buy two 100 ft 30 amp cables and have my electrician cut them and install a couple of sockets in the transom (just like almost every other boat) so I could disconnect them prior to setting out on a trip (just like other boats). Other than that, she's a beauty!
Can you provide me a picture of what that new shore power connection looks like? I've been having problems with all of that cable wound up in the aft locker and I'd like to get rid of it and use that space for something else.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » March 2nd, 2023, 6:43 am
I know what your talking about. Way too long. Where the cables pass in the boat, you'll see a white plastic grommet it goes through. Loosen that buy un-screwing it and you will be able to push a lot of cable into it's storage behind that panel. That helps by not having so much cable in the locker.
