Why does genny draw fuel only from port tank?
- Adaptel
- Vessel Info: 2001 Carver 356 Aft
- Has thanked: 1 time
- Been thanked: 25 times
I have a 2001 Carver 356 and I find is incredibly strange that the generator is setup so that it always draws fuel from the port tank only. My boat as an aux fuel tank under the swim platform and it just makes sense that the generator should get its fuel from there to prevent imbalance from running generator. Both propulsion engines have a fuel selector valve to select either main side tank or aux tank, but generator is always port tank. Why?!?!?!
I was thinking of re-configuring this by adding a third fuel selector valve for the generator to select aux or port tank. Is there any reason for not doing so? Common sense is telling me that I would need to install another fuel line, pickup tube, and anti-siphon valve on the aux tank to prevent fuel starvation by tapping into existing fuel line. Is this correct? Any thoughts?
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Why does genny draw fuel only from port tank?
In addition, when I refuel, whether partial or fill up, I always ensure the tanks carry approximately the same level.
The fuel consumption of the Genny is so minimal, it is difficult to see a significant difference.
As for putting in valves to have it draw from your aux. as an option, not sure the end would justify the means, however, that is entirely up to you.
I wouldn't even consider that expense on my boat and we use our Genny a lot. JMHO...
Greg
- Tireless
Greg
- Tireless
Greg
- Adaptel
Tireless wrote:Source of the post It has never caused me any issues over the years, due to a fuel imbalance. I have a fuel transfer
After really hot weekends when I run my generator a lot, I definitely have a very noticeable fuel imbalance between port and starboard tanks, and have to either run the starboard engine on the AUX tank until balanced....or get some fuel prematurely. My boat does not have a transfer valve/switch. Was that an optional feature, or added after a certain year?
As mentioned, it's pretty standard for the carvers to pull from port tank only.
I have always planned to put in a selector and run my genny from the aux tank but never did. On the few occasions I run the genny enough to make a big difference, I switch the port engine to pull from the starboard tank for a bit if I don't plan to refuel soon.
Unless you boot around all the time at high speed, you can run both engines off one tank, the one with the most fuel, until it's even with the lower tank.
Fuel transfer pump options are on diesel applications only.
- Been thanked: 654 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
