Starting Issue
- captainndiet
- Vessel Info: 38 ft Santego 2002
Volvo 8.1 GI-IA - Has thanked: 4 times
Starting Issue
I have a 2002 380 Santego powered by 2 8.1 GI-IA Volvo engines. Recently the port engine has been giving me some starting issues.
Last weekend ran great started every time.
Prior week.
I turned the key no audible alarm, the engine would crank but not start.
I am worried that one time I am able to leave port and I go to return the intermittent problem will leave me in the gulf with only 1 engine
I did some research and I had my battery switch on both all the time Since last weekend I turn if off when not at the boat and I rotate from 1 to 2 every other day.
Should I look at the relays or is this possibly a charging issues
Member Clearwater Yacht Club
2002 380 Santego Carver / current
1997 230 Express Monterey
2005 370 Express Cruiser
1983 24 Pro Line w/1993 175 Evinrude
1997 30 Chaparral
1994 24 Stingray
Re: Starting Issue
- Does this happen the first time you try starting on the weekend or will it happen any time like a couple of hours after a run, you try and it won't start again?
- Is it always a no start symptom or has it stalled out as well?
- When it cranks and won't start, can you hear the fuel pump working?
- When were the plugs last changed?
- Have you checked to ensure the harness plug and all other plugs are tight, contacts are clean, etc?
- I believe there is an ignition breaker and a relay box. Check the connections at all these points. I've also had issues with the breakers.
- Make sure the batteries are good, have them tested, and ensure the connections are tight and clean at the battery end and the engine end.
The more info you can provide, the better.
The good thing about having twins is that you can swap out parts from one engine to the other and see if the problem follows the part. Just make sure you change only one part at a time, and once you're convinced it's not the issue, put it back in the original engine and then swap out the next part. This way you'll know for sure which part is faulty.
summerda
- Vessel Info: 3807
Re: Starting Issue
Good luck.
Re: Starting Issue
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Re: Starting Issue
Again, the 8.1Gi has an electronic fuel injection that has proven very reliable, so fuel issues are usually supply-related. Any chance of water in the tank? What you are describing can be caused by some water getting in the fuel system. Do you have a gas/water separator? Check it and see what's there. If you don't have a separator, put a bottle of fuel treatment (I like the StarBrite Star-Tron) in the tank that feeds the troubled engine, run the boat around a bit, and see if it fixes the problem.
After these easier-to-check things, you would need to move on to more detailed troubleshooting.
Hope this helps and good luck!Past Commodore, Peninsula Yacht Club
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- captainndiet
Re: Starting Issue
1997 30 Chaparral
1994 24 Stingray
