big problem 454 xl
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
Re: big problem 454 xl
- RobGunn
- RobGunn
- Has thanked: 603 times
RobGunn wrote:Source of the post Also, I have heard that there are options available to "Seal" a block. Im not familiar with this option but I have heard that it is doable. Maybe a few internet searches could give you some info? Keep in mind that the cooling of a marine engine is normally not under pressure like a Automotive engine is. Basically a marine engine is just circulating raw water to cool it.
That would only apply to raw-water cooled engines, but that does appear to be what the OP is dealing with.
You also have to figure that a marine engine block is under a WHOLE LOT more stress than an auto or truck engine. That marine block is flexing (or trying to) much more than an auto or truck because they are working much harder for a much larger percentage of their life. A solution that might work on the auto or truck engine for a long time might not last in a marine application.
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
Buster, could you post your engine info? The OP's may both be toast (hope not!) and I may have to replace my originals in the future and am searching for successful prospects. Thanks.
Phil Little
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
Our boat that we just purchased, had both Volvo 7.4 gas engines rebuilt at a cost of $26,000, and the owner opted for Volvo long blocks, which means that it was probably an insurance job. If it was not an insurance claim, then I would find a couple of good used 454 blocks and used proper marine components to rebuild them both for probably quite a bit cheaper than the Volvo long blocks.
If it was me, I would go for a new block rather than try welding a block.
Just my own opinion of course!
Love this Carver forum!
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
