Cruising Range 2008 Mariner 330 5.7 Crusader Gas
- MBoone
- Vessel Info: 2008 CarverMariner
- Has thanked: 6 times
Ideas to increase speed range of this boat?
Thanks,
MJB
Re: Cruising Range 2008 Mariner 330 5.7 Crusader Gas
Note too that the distance travelled would be significantly affected by the river currents, either increasing or decreasing the amount by quite a bit. IIRC, if you're going WITH the current, you'd probably want to travel as slow as you can (hull speed if possible), to get multiples of the MPG. Going against the current it's more of a time thing, where you'd want to at least be on plane.
- Has thanked: 602 times
MBoone wrote:Source of the post Ideas to increase speed range of this boat?
Welcome to the forum.......run the boat at around 7 knots ( around 6-7 GPH total ), it will take considerably longer but will extend the range total.....remember to employ the 1/3 rule for safety to cover the unknowns.......1/3 out, 1/3 back and 1/3 in reserve if heading to open water.
Good luck with your travels.....
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
