New member
Carver37c
Vessel Info: 2015 carver37c
New member
Postby Carver37c » May 4th, 2023, 9:03 pm
I just purchased a 37c. I am looking for any information people have about them. It seems to be a nice Boat but I am sure there are things that will need fixed.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: New member
Postby buster53 » May 4th, 2023, 9:21 pm
What did your surveyor have to say? Did he/she find any issues?
Been thanked: 470 times
Re: New member
Postby RGrew176 » May 5th, 2023, 12:48 am
Welcome Aboard. Good luck with your Carver.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Re: New member
Postby pepmyster » May 5th, 2023, 5:26 am
Welcome!!!!!!!!!!!!!!!!
Re: New member
Postby Viper » May 5th, 2023, 6:39 am
Congrats and welcome aboard :down:
Re: New member
Postby km1125 » May 5th, 2023, 8:08 am
Welcome aboard!
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Re: New member
Postby ColRon » May 5th, 2023, 9:51 am
Congratulations and welcome aboard!
Ron
“Escape Plan”
Murray, KY
:usa:
Been thanked: 491 times
Re: New member
Postby waybomb » May 5th, 2023, 4:59 pm
Welcome aboard!
Carver37c
Re: New member
Postby Carver37c » May 5th, 2023, 9:50 pm
Survey just found a couple small issues with the upholstery and nicks in gel coat. One thing I notice is the a/c unit is not discharging water out the side. I can hear the pump running and the sea cock is open and strainer is clean.
buster53
Re: New member
Postby buster53 » May 6th, 2023, 1:08 am
Carver37c wrote:Survey just found a couple small issues with the upholstery and nicks in gel coat. One thing I notice is the a/c unit is not discharging water out the side. I can hear the pump running and the sea cock is open and strainer is clean.
Yes, your pump could be the problem and needs replacing, but try priming the system first. Could easily have an air lock. When you open the strainer, is it full of water? Assuming it is below the water line, water should be overflowing if the seacock is open.
Did your surveyor not make a note of that?
Users browsing this forum: No registered users and 59 guests
