Windless Issue
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Windless Issue
Yesterday as I was dropping the anchor (my 2005 Mariner has 150 ft of chain), it quit working. I flicked the switch on/off thinking it was the connection but then realized that it was getting power because I heard a 'whirring' sound at the motor but no chain action. I attached the manual crank and found out that it the chain is frozen in place. The chain cannot be moved in either direction.
All thoughts and advice are welcomed. I am hoping that I will not have to replace this expensive item.
- Has thanked: 603 times
Re: Windless Issue
You say the motor is turning ? .....Go below and watch ( check shaft for motion ) to verify. Did you clean the contacts or just spray stuff in them?
There are online manuals for these things that may walk you thru troubleshooting your specific problem.....good luck man.
- Thelma Jean I
- Vessel Info: '95' Carver Santego 380
- Has thanked: 21 times
Re: Windless Issue
Re: Windless Issue
Users browsing this forum: KyleR and 24 guests
