New member
Carver37c
Vessel Info: 2015 carver37c
Re: New member
Postby Carver37c » May 7th, 2023, 12:49 pm
No he did not. He said the heating a\c worked as desired. When I went to look at the boat a couple days later I noticed it was not spraying Water out of either unit. I am hoping I just need to Prime it. I have had to do that before on other boats I have had. This is the first boat I have had that has two a\c units. The sea strainer is fine because when I take cap off strainer Water will flow out of it when I open sea cok. It was just delivered to my marina Saturday so I am hoping to start working on things this week.
Re: New member
Postby km1125 » May 7th, 2023, 3:47 pm
If the prime doesn't take care of it you might also just have some gunk on the impeller. Just take the end off the pump and inspect/clean the impeller if that's the case. Then reprime.
Users browsing this forum: Google Adsense [Bot] and 36 guests
