2005 Carver CMY 41 Cockpit hatch drain clogged
- NewtRobson
- Vessel Info: 2005 Carver CMY 41
- Has thanked: 3 times
Newt
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 2005 Carver CMY 41 Cockpit hatch drain clogged
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
Best drain "clearer" I ever found is a length of stiff nylon tubing 1/4" OD. Just push it in and the debris is pushed out. No damage if reasonably gentle.
- Has thanked: 602 times
- NewtRobson
bud37 wrote:Source of the post Welcome to the forum......wet dry shop vac on suck or blow, great tool on board for clearing drain lines without damage and general whatever.
Hi, yes I tried all of the above before I posted. Problem is I'm not sure where the drain inlet is located. The water runs off the deck and along the walls of the transom. It appears I have to unscrew the decking to reach it. Any other ideas are welcome. Thanks, Newt
The drain line is located right where the center hatch opens, a large seacock is there where it exits through the hull. Is that seacock open? If not, nothing is going to drain.
Users browsing this forum: No registered users and 70 guests
