Dash switches.....
jhnybgood
Vessel Info: 1991 CARVER 26 COMMAND BRIDGE
Dash switches.....
Postby jhnybgood » May 26th, 2023, 10:55 pm
I need a NAV light switch for my old 1991 26 command bridge. West Marine was a no go. Did google picture search....close....but no. Really don't want to have to change both female end to match a diff swith if ya know what I mean.... Anyone have a connection?
Re: Dash switches.....
Postby km1125 » May 27th, 2023, 8:07 am
I think the cover snaps off there and then it's a pretty standard switch underneath. What are all the numbers printed on the sides of the switch?
Postby Viper » May 27th, 2023, 9:09 am
It's just a DPDT Carling switch. You can get the entire assembly or just the switch itself and install your existing rocker on it. Any brand of DPDT switch that will accommodate that rocker design will work. Is every terminal on the switch actually being used; 6 wires?
jhnybgood
Postby jhnybgood » May 27th, 2023, 10:12 am
km1125 wrote:Source of the post I think the cover snaps off there and then it's a pretty standard switch underneath. What are all the numbers printed on the sides of the switch?
No number on switch. Just 12v Mexico Carling.
jhnybgood
Postby jhnybgood » May 27th, 2023, 10:13 am
Viper wrote:Source of the post It's just a DPDT Carling switch. You can get the entire assembly or just the switch itself and install your existing rocker on it. Any brand of DPDT switch that will accommodate that rocker design will work. Is every terminal on the switch actually being used; 6 wires?
That I don't know. Just bought the boat. It's the nav light switch so I don't know why they would be. Gonna chase the wires today and see
Postby Midnightsun » May 27th, 2023, 10:48 am
jhnybgood wrote:Source of the post
Nav lights have a tendency of being left on and burning out. I know you want to change the switch but have you checked the nav light sockets for power?
jhnybgood
Postby jhnybgood » May 27th, 2023, 1:11 pm
Midnightsun wrote:Source of the post
The starboard one is good for sure. Port? Need to get it apart. The screw heads are stripped.
jhnybgood
Postby jhnybgood » May 27th, 2023, 1:22 pm
Starboard is good for sure. Can't open port because the screw heads are stripped.
Postby bud37 » May 27th, 2023, 4:47 pm
jhnybgood wrote:Source of the post Starboard is good for sure. Can't open port because the screw heads are stripped.
You would be surprised what you find inside those things.....sometimes a little cleaning of the socket and grounds then continuity check is all that is needed.
jhnybgood
Postby jhnybgood » May 28th, 2023, 11:22 am
Got the lights working with the bridge switch. Still want to find a replacement for the cabin switch, but one issue solved. Thanks for all the replies
Users browsing this forum: No registered users and 3 guests
