2007 36 MY rudder mount leak/corrosion
- CKSflier
- Vessel Info: 2007 36 MY
Volvo D6-310s - Location: Georgia
- Has thanked: 2 times
My mechanical vendor did not feel additional anodes were needed for freshwater lake use (they were on the trim tabs); the boat had an unknown amount of saltwater exposure over its lifetime, but this was not evident in its overall condition.
Fast forward to now: I was diagnosing a #3 bilge light and found the starboard rudder leaking with corrosion on the shaft mount/bolts as it goes thru the hull (the pre-purchase CVS didn't observe this area). With much effort, I got my inspection camera cable to the port side with similar results.
The bow/stern thrusters nuts also show rust and driveshaft mount hardware shows corrosion, so more anodes will be installed on all exposed assemblies.
Questions:
Does anyone have a 2007 36 MY parts manual so I might “attempt” a search for replacement rudder mounts? (and shafts, if necessary)
And/or: Can anyone recommend where mounts/shafts could be obtained or replicated?
Re: 2007 36 MY rudder mount leak/corrosion
Anodes likely won't stop what you're seeing there, but they should be installed whether you're on fresh or salt. You never know who you're going to be docked near and a fault in their electrical wiring could affect your vessel. Most of what I see is caused by moisture (and air) INSIDE the boat, whereas the anodes would protect what's OUTSIDE the boat in the water.
Once it's cleaned up, I'd see if all that needs is some adjustment to the packing to stop the leak.
- Has thanked: 603 times
