530 saloon door removal
Topic author Australia
aussie530carver
Vessel Info: 1999 Carver 530 pilothouse
Postby aussie530carver » July 6th, 2023, 10:19 pm
Hi all my sliding glass door saloon door is getting harder to slide open ... im thinking it may need new rollers .. so has anyone attempted to remove the glass sliding door, does it have a roller type system, is there a procedure to removing it.. any pictures would be great ..cheers
Pura Vida
Vessel Info: 93 Carver Mariner 330. 2X 350XL Crusaders
Has thanked: 17 times
Been thanked: 10 times
Re: 530 saloon door removal
Postby Pura Vida » July 15th, 2023, 8:19 pm
Helpful link:
Re: Repair Sliding Glass Door
viewtopic.php?f=7&t=5679&p=56423&hilit=door#p56423
The trick on ours was to remove plastic slider on the top first, pulls right out afterward.
mjmason1
Vessel Info: 1999 Carver Voyager 530
Has thanked: 2 times
Been thanked: 19 times
Postby mjmason1 » July 24th, 2023, 8:32 pm
I just did mine. I wish I had taken pictures. It was easy. It took less than an hour. I ordered the rollers from England. All you have to do to remove the slider is unscrew the track at the bottom and slide the door and the track out. The door is heavy so get plenty of help. The new rollers need a different screw to attach to the door, so get them ahead of time. You will slao have to drill the door frame to enlarge the screw hole. No big deal. Simply put in the new rollers and loft the doo back into place while sliding the track with it. Then adjust the rollers so the door slides easily and the lock lines up.
