Port Engine won’t start
- Thelma Jean I
- Vessel Info: '95' Carver Santego 380
- Has thanked: 21 times
Thanks!!!
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Has thanked: 1 time
- Been thanked: 8 times
Re: Port Engine won’t start
- Thelma Jean I
Viper wrote:Source of the post I'm assuming she's cranking/turning over but won't run? If that's the case, as mentioned, go back to basics and make sure you're getting spark and fuel. Last time ignition tune-ups were done? Does she have spin-on fuel filters and are they full of fuel? Does it crank over really easy or is she labouring?
Yes it wont run.. battery power is there, fuel is working properly (New fuel filters for both sides). Once I have time later in the week, my brother and I will check on the spark plugs an I will certainly give an update. Thanks
- Thelma Jean I
km1125 wrote:Source of the post Does this affect both engines or just one of them?
Just the port side.. checking spark plugs later in week.
- Thelma Jean I
Thelma Jean I wrote:Source of the postViper wrote:Source of the post I'm assuming she's cranking/turning over but won't run? If that's the case, as mentioned, go back to basics and make sure you're getting spark and fuel. Last time ignition tune-ups were done? Does she have spin-on fuel filters and are they full of fuel? Does it crank over really easy or is she labouring?
How do you know "fuel is working properly"... have you checked the fuel rail pressure before or while trying to start?
Were the filters pre-filled when you replaced them? How long ago were they replaced, and has the engine run fine since then until now?
- Thelma Jean I
Spark plugs changed, ignition coil and module replaced. Engine still will not start. I've gotten the suggestion that a scan tool may be needed now.
Did you check fuses and breakers? If there's fuel pressure in the rails, are the injectors firing? Do the plugs get wet from gas? Have you checked that any of the plugs are actually firing with a good, hot spark?
Users browsing this forum: Google Adsense [Bot] and 48 guests
