Volvo Fuel Filters
TruckerTim
Vessel Info: 2000 Voyager 450
Sarasota, FL
Volvo Fuel Filters
Postby TruckerTim » July 11th, 2023, 9:51 am
Looking for the filter numbers for both the small and larger spin on filters for my Volvo TAMD 74. Not at the boat and need to order them. Thanks!
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: Volvo Fuel Filters
Postby Cooler » July 11th, 2023, 10:37 am
The Volvo's are either 3825133 or 21492771. After market Sierra is 18-7942. Fuel Filters. There are a series of TAMD 74's. There should be two Letters after 74. Good luck! 8-) er
Cooler By The Lake
TruckerTim
Sarasota, FL
Postby TruckerTim » July 11th, 2023, 1:20 pm
Thanks. I think mine are 74A, but don't remember another letter after the A. I did see one filter is bigger than the other, but working of old memory.
TruckerTim
Sarasota, FL
Postby TruckerTim » July 11th, 2023, 1:56 pm
TAMD 74P-A
Netherlands
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Postby Phrancus » July 13th, 2023, 9:46 am
That would be the P*** in the A** version :beergood:
any size filter (tall/short depending on place available too) that fits the threads will do as long as the throughput/flow is equal. I found a site with a range of replacement part numbers for trucks/tractors and many filter brands. (not at hand right now, sorry) so you can pick from a range of brands.
I stick to the main brands (I'm in Europe) such as MANN, Mahle, Bosch, Hengst and such. These are already way cheaper than VP without giving in on quality.
tip: when you get the right one, stock up (also on fuel filters) so you can change without the figuring out and wait for delivery hassle next time.
Cooler
Postby Cooler » July 13th, 2023, 12:31 pm
Trucker. The part numbers above are correct for your version. The Sierra after market parts are just as good, easier to find. good luck. 8-) er
Cooler By The Lake
TruckerTim
Sarasota, FL
Postby TruckerTim » July 13th, 2023, 5:14 pm
Great info Thanks all.
