Temp Gauge
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Temp Gauge
Has anyone seen a source for this temp gauge?
Thank you!
Best,
Tony
- Has thanked: 602 times
Re: Temp Gauge
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Temp Gauge
Re: Temp Gauge
I doubt they're still available but have you tried contacting VDO? You can also try surplus retailers like Great Lakes Skipper.tonyiiiafl wrote:Source of the post....Has anyone seen a source for this temp gauge?...
Have you confirmed the temp at the sender with an IR temp gun?
You have closed cooling right?
What temps are both engine running at?
- tonyiiiafl
Re: Temp Gauge
- tonyiiiafl
Re: Temp Gauge
I am going to buy an IR temp gun this week and see where things really are.
You all are the best.
Best,
Tony
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Has thanked: 1 time
- Been thanked: 8 times
Re: Temp Gauge
It’s not a hard thing to do and is some I add to my annual maintenance routine.
Re: Temp Gauge
tonyiiiafl wrote:Source of the post I have the Starboard engine hooked into the water heater. Port running at 160is. New gauges 9As port was a bit erratic) and now sits at 160 at idle, still need to take it out. Starboard is running around 165-168 at idle. I can see it go up and thermostat open and go down. I bought a couple of Sierra gauges as they had the 100 to 220 range as teh VDO have. Now looking for a sensor that is 100 to 220
I'm wondering if you don't really have a sticky thermostat. You really shouldn't see the temp go up and down with a constant load. As it approaches the set temperature it starts to open, so even before it's fully open additional cooling is happening. If there's not enough heat being generated, it should never fully open and just regulate the flow based on the set temperature.
Re: Temp Gauge
- tonyiiiafl
Re: Temp Gauge
Users browsing this forum: Google [Bot] and 34 guests
