12vdc fridge, will not run when shore power is diconnected
- bobwhorn
- Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
- Has thanked: 3 times
- Contact:
Thanks,
Bob
- Has thanked: 603 times
Re: 12vdc fridge, will not run when shore power is diconnected
Look on the panels inside the fridge. There's usually a sticker there on the side which gives a lot of information about the make and model.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- bobwhorn
- Contact:
- buster53
bobwhorn wrote:The name plate clearly states 12/24 vdc. It's a Coolmatic. All the door shelves are gone. Any possible sources?
Ok, not familiar with that model…however, is it also a 120 volt as you say the name plate only says 12/24. Just maybe, your batteries are getting bad and the refrig only works when plugged into shore power and the battery charger is really running the frig and not the batteries. Just a thought.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
“Escape Plan”
Murray, KY
- ColRon
“Escape Plan”
Murray, KY
- bobwhorn
- Contact:
