121805eg c-charger 5000 out of commision
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: 121805eg c-charger 5000 out of commision
so the 2 batteries are #1 for engine #2 for house. But current charger is charging all 3.
All 3 batteries are multipurpose deep cycle marine AGM batteries, purchased at NAPA Auto Parts.
Here is post I made on the Charles unit although mine was a 60A. viewtopic.php?f=12&t=3966&hilit=charles
- cpoint
- cpoint
With a typical 356 I wouldn't go with 40 or less. 50 or 60 would be fine. If you had a huge house bank then I'd be pushing for a larger charger... at least 25% of the rated amp-hours on the house bank.
- Has thanked: 602 times
- cpoint
I think you missed the part that the Charles units divide it's total output into 3 banks and does not output more even to any one even if other banks are full. Basically your house bank never sees an 80a charge on the Charles, 28a at best. A 50a Pronautic will charge 50a to the house bank assuming the 2 start batteries are full which they normally are. Bottom line is even a 30a Pronautic will equal an 80a Charles when it comes to supplying a house bank in need. A 50a Pronautic is a big upgrade from the 80a Charles you have.
- cpoint
Midnightsun wrote:Source of the post cpoint,
That's not really true. The Charles charger uses diodes to isolate the outputs, just like the Pronautic. So they're both single chargers with diode-isolated outputs. The charge delivered to each output is based on the load, so any of the outputs can consume up to the rated load of the charger. This means any of the individual outputs, or a combination of all outputs, can supply the total rated current of the charger.
This is different than some chargers with isolated outputs where there is a dedicated amount of charge to each bank, say a 2x10A or 3x20A where each output is limited to 10A or 20A. These are essentially multiple smaller chargers built into one case.
