Need Crusader 30233 choke spring (454 350hp)
- Been thanked: 490 times
Everywhere I've looked finds none.
Anybody?
- Has thanked: 602 times
Re: Need Crusader 30233 choke spring (454 350hp)
I'm thinking I can drive the mounting pin out, turn the spring around, and drive the pin back in, noting the orientation of the notch on the one side.
Thoughts?
Being the backyard jerk I can be, I set the pin in place, crimped down what I could, and then jb welded the pin in place on both sides.
We'll see if this works. Have to wait for jb to cure.
When the unit is built, the parts are assembled then inserted into a machine to pinch the tabs down on the "pin" to prevent it from rotating. After many heat/cool cycles, this may become loose and cause the choke "spring" to rotate, making it ineffectual on the choke butterfly. You can re-stamp (or re-stake) these tabs to stop the "pin" from rotating.
