Carver 3807 prop size
- baker.p@comcast.net
- Vessel Info: 1988 Carver 3897 twin Mercruiser 7.4
- Has thanked: 3 times
Re: Carver 3807 prop size
I had 22x22 on a 3607 and it used 2.57 gears (and with Crusader 350HP).
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
FWIW, I now have a 356 with Crusader 8.1's, putting out 385 HP. Smaller, lighter boat with bigger, more powerful engines, meaning I can swing a bigger prop than the 3807 you are looking at. I'm currently turning 22x26.
As mentioned above, until you know what the transmission gear reduction ratio is, you are really just shooting in the dark.
My ratio is 2.52.
- Has thanked: 602 times
To be clear are you saying it won't get up on plane and 3000 is max at that point ?
- buster53
A couple years ago, my boat went back in the water after winter haul out with fresh bottom paint. Whatever the boat yard used on my running gear didn't work. The bottom was nice and clean, but in the short period of 10 weeks, my running gear loaded up enough to cut 8 MPH off my top speed. In 10 weeks, I went from 35 MPH all the way down to 27.
Yes, I agree you are probably overpropped and that needs attention, but more than likely, you have running gear loaded up with barnacles.
- buster53
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
Top rpm was 3500, and top speed was 18 knots. I wanted the engines to top out at 4200-4400 rpm with full fuel and water. We worked with the local prop shop, and wound up with 16” X 17” 4 blade props. Top rpm was 4400 rpm, and top speed jumped up to 26 knots.
The prop shop told me that every 1” less diameter equals about 200 more rpm, and every inch less pitch increases rpm by roughly 100 rpm.
Hope this helps.
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
